poIPostManager GetMaximumMemoryUsage
Gets the maximum percentage of physical memory that the post client should use.
poIPostManager_handle GetMaximumMemoryUsage
HyperView Tcl Query
This command retrieves the maximum percentage of physical memory that the post client should use.
Returns the percentage actually set (values below 20% are not permitted).
