poIPostManager SetReaderPropertyValue
Sets the property value for the specified reader.
poIPostManager_handle SetReaderPropertyValue prop value reader_name
HyperView Tcl Modify
This command allows you to set "Reader Options" by providing the option (property) name and its value, as well as the reader name. The list and the meaning of the reader options vary from reader to reader.
prop
The property defined by the reader.
value
The value to be set for the property.
reader_name
The name of the reader.
hwi OpenStack
hwi GetSessionHandle session_handle sess_handle
sess_handle GetClientManagerHandle mgr Animation
mgr SetReaderPropertyValue "Model Organization" "By 1 Component" "Nastran/Optistruct Model Input Reader"
hwi CloseStack
Returns 0 if successful, or a non-zero value if there is a failure.
