poIQueryCtrl GetSelectionSetSize
Gets the size of the entities selection set that will be used to query the HyperView database.
poIQueryControl_handle GetSelectionSetSize
HyperView Tcl Query
This command retrieves the size of the entities selection set that will be used to query the HyperView database.
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetQueryCtrlHandle myQueryName
myQueryName GetQuery GetSelectionSetSize
Returns the size of the entity selection set, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
