poIQueryCtrl SetDataSourceProperty
Sets the new value for a specified property for a given data source.
poIQueryControl_handle SetDataSourceProperty source property value
HyperView Tcl Modify
This command sets the new value for a specified property for a given data source.
source
The source for which the property is to be set.
property
The property to be set.
value
The value of the property to be set.
To set the datatype property of result (source) to Stress:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetQueryCtrlHandle myQueryName
myQueryName SetDataSourceProperty result datatype Stress
Returns 0 if successful, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
