poIQueryCtrl SetRemoveDuplicates
Sets the state of the remove duplicates option in the query handle.
poIQueryControl_handle SetRemoveDuplicates state
HyperView Tcl Modify
This command sets the state of the remove duplicates option (which will remove duplicate node data queried when set to True).
state
Boolean value to set the remove duplicates state (True/False).
To remove the duplicate node data queried:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
set sid [model_handle AddSelectionSet node]
model_handle GetSelectioSetHandle selset_handle $sid
selset_handle Add all
model_handle GetQueryCtrlHandle query_handle
query_handle SetRemoveDuplicates true
query_handle SetQuery “node.id node.coord component.id”
query_handle SetSelectionSet $sid
query_handle GetIteratorHandle iter_handle
for { iter_handle First }  { [iter_handle Valid] } { iter_handle Next } {
      iter_handle GetDataList
hwi CloseStack
Returns an error if the value state cannot be applied.
