poIRenderOptions GetAntiAliasing
Gets the current anti-aliasing setting.
poIRenderOptions_handle GetAntiAliasing
HyperView Tcl Query
This command retrieves the current anti-aliasing setting. Returns true if anti-aliasing is enabled and false if anti-aliasing is disabled.
To get the current anti-aliasing setting:
hwi OpenStack
session_handle GetClientManagerHandle anim_handle animation
anim_handle GetRenderOptionsHandle render_handle
render_handle GetAntiAliasing
hwi CloseStack
None.
