poIRenderOptions SetDABEnabled
Allows you to enable or disable the Display Acceleration Block (DAB) display acceleration.
poIRenderOptions_handle SetDABEnabled state
HyperView Tcl Modify
This command allows you to enable or disable the Display Acceleration Block (DAB) display acceleration.
Note: When DAB is enabled the display will be faster, especially for large models, however some artifacts may be noticed (especially when shell elements are on top of solids).
state
Set to true to enable DAB display acceleration.
Returns 0 if successful, otherwise an error code.
