poIRenderOptions SetGeneratedLineThickness
Sets the thickness of lines generated from iso value and section cut operations.
poIRenderOptions_handle SetGeneratedLineThickness thickness
HyperView Tcl Modify
This command sets the thickness of lines generated from iso value and section cut operations.
thickness
The thickness of the generated lines.
Returns 0 if successful, otherwise an error code.
