poIResultCtrl GetDataComponentTransformable
Returns true if the component/derived type for the specified result allows system transformations.
poIResultCtrl_handle GetDataComponentTransformable subcase_id datatype datacomp
HyperView Tcl Query
This command returns true if the component/derived type for the specified result allows system transformations.
- subcase_id
- Set to a positive integer.
- datatype
- The data type label.
- datacomp
- The data component label.
Returns true if transformation is allowed. Otherwise, false.
