poIResultCtrl GetDataDimensionList
Gets the list of dimensions with non-empty datasets. Values include: node, line, shell, or solid.
poIResultCtrl_handle GetDataDimensionList subcase_id datatype
HyperView Tcl Query
This command retrieves the list of dimensions with non-empty datasets. Values include: node, line, shell, or solid.
- subcase_id
- Set to a positive integer.
- datatype
- The data type label.
Returns node, line, shell, or solid if the data type exists. Otherwise, an empty string.
