poIScalarDefine GetProjectionRule
Gets the projection axis information.
poIScalarDefine_handle GetProjectionRule
HyperView Tcl Query
This command, valid only in Upfront Data Loading Mode, returns the projection axis information for the result definition as a string of the form: "<primary> <secondary>" or "none" if no projection rule is defined.
To get the projection axis information for a result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine GetProjectionRule
hwi CloseStack
None.
Related Topics
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
