poIScalarDefine SetProjectionRule
Sets the projection axis information.
poIScalarDefine_handle SetProjectionRule rule
HyperView Tcl Modify
- rule
- String in the form: "<primary><secondary>" to used a projection rule or "none" to disable projection rule, where primary/secondary is mapped as follows" 1 = X, 2 = Y, 3 = Z.
To set the projection rule to XZ for a result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine SetProjectionRule "1 3"
hwi CloseStack
Returns an error code if there was an error setting the projection rule and sets error condition on the session handle. See session_handle GetError.
Related Topics
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
