poIScalarDefine SetResultSystem
Sets the result system of the result definition.
poIScalarDefine_handle SetResultSystem sys_id
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, sets the result system ID. This is either a valid result system locator of the form "id pool_name" or one of the special identifiers. Returns Success (0) or an error code.
Note: The result definition can only be modified if it is not cached.
sys_id
This is either a valid result system locator of the form "id pool_name" or one of the following special identifiers:
  • 0:global system
  • -1: analysis system
  • -2: elemental system
  • -3: tracking system
  • -4: material system
  • -5: ply system
To set the result system of a scalar result definition to analysis system:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine SetResultSystem -1
hwi CloseStack
Returns or an error code if there was an error setting the result system and sets error condition on the session handle. See session_handle GetError.
Related Topics
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
