poIScalarDefine SetValueFilter
Sets the value filter values.
poIScalarDefine_handle SetValueFilter from to
HyperView Tcl Modify
- from
- The value filter if the value type is “<=” or “>=” or the ‘from’ value filter if the value filter type is “Range”.
- to
- The ‘to’ value filter value which is used if the value filter type is “Range”.
To set the value filter range from 25 to 50 for a result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine SetValueFilterType Range
sdefine SetValueFilter 25 50
hwi CloseStack
None.
Related Topics
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
