poISCL GetID
Gets the ID for the Stress Characterization Line (SCL).
poISCL_handle GetID
HyperView Tcl Query
This command returns the ID for the Stress Characterization Line (SCL).
To get the ID for the Stress Characterization Line (SCL):
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl GetSCLHandle scl_handle scl_id
scl_handle GetID
hwi CloseStack
None.
