poISCL SetColor
Sets the color for the Stress Characterization Line (SCL).
poISCL_handle SetColor color_str
HyperView Tcl Modify
This command sets the color for the Stress Characterization Line (SCL). The default value is White (255 255 255).
- color_str
- The color string for the SCL.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl GetSCLHandle scl_handle scl_id
scl SetColor color_str
hwi CloseStack
None.
