poISCL SetN2
Sets the end point for the Stress Characterization Line (SCL).
poISCL_handle SetN2 n2
HyperView Tcl Modify
This command sets the end point for the Stress Characterization Line (SCL).
n2
Node 2.
To set the end point for the Stress Characterization Line (SCL):
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl GetSCLHandle scl_handle scl_id
scl SetN2 node_id_str
hwi CloseStack
None.
