poISection GetDeformMode
Gets the deform mode. Section cuts operate in either deformable or section_type (planar or spherical) mode.
poISection_handle GetDeformMode
HyperView Tcl Query
This command retrieves the deform mode. Section cuts operate in either deformable or section_type (planar or spherical) mode.
Returns true if the section mode is deformable, or false if it is not.
