poISection SetBaseFrame
Sets the section base frame (for deformable sections only).
poISection_handle SetBaseFrame
HyperView Tcl Modify
This command sets the section base frame. Applies to deformable sections only.
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle post_handle
post_handle GetSectionHandle section_handle [post_handle AddSection 0]
# Set frame
section_handle SetBaseFrame 2
hwi CloseStack
Returns an invalid handle.
