poISection SetClipAbove
Toggles the current direction for the section.
poISection_handle SetClipAbove state
HyperView Tcl Modify
This command toggles the current direction of the clipping surface for the section. Set to "True" to clip above the section surface, or "False" to clip below.
- state
- The state for the current clipping direction.
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle post_handle
post_handle GetSectionHandle section_handle [post_handle AddSection 0]
# Set clipping direction
section_handle SetClipAbove false
hwi CloseStack
Returns an invalid handle.
