poISection SetDisplayOption
Sets the state of the given section display option.
poISection_handle SetDisplayOption name value
HyperView Tcl Modify
This command returns the state of the given section display option.
name
The name of the section display option:
“gridlines”
Display of grid lines.
“grixtext”
Display of values around the grid.
value
The boolean value for the section display option.
To set the state of a section display option:
hwi OpenStack
hwi GetClientHandle post_handle
post_handle GetSectionHandle section_handle [post_handle AddSection 0]
# Get gridtext status
section_handle SetDisplayOption “gridtext” true
hwi CloseStack
Returns an invalid handle.
