poIStressLinearizationCtrl ComputeLinearizedStressComponents
Generates the linearized stress components for the Stress Characterization Line (SCL) specified by ID.
poIStressLinearizationCtrl_handle ComputeLinearizedStressComponents id
HyperView Tcl Modify
This command generates the linearized stress components for the SCL specified by ID.
id
The ID of the Stress Characterization Line (SCL).
To generate linearized stress components for a Stress Characterization Line (SCL):
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl ComputeLinearizedStressComponents scl_id
hwi CloseStack
None.
