poIStressLinearizationCtrl SetUseCurrentContour
Instructs the Stress linearization controller whether or not to use the currently contoured data type for stress linearization.
poIStressLinearizationCtrl_handle SetUseCurrentContour useCurrent
HyperView Tcl Modify
This command instructs the Stress linearization controller whether or not to use the currently contoured datatype for stress linearization.
useCurrent
The currently contoured datatype to be used.
To instruct the Stress linearization controller to use the currently contoured datatype for stress linearization:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl SetUseCurrentContour flag
hwi CloseStack
None.
