poISubcase GetDataComponentComplexFilter
Returns whether or not the data component can be used with various complex filters.
subcase_handle GetDataComponentComplexFilter datatype datacomp
HyperView Tcl Query
This command returns whether or not the data component can be used with various complex filters (true or false).
datatype
The data type for the components which are requested.
datacomp
The label of the data component for which the complex filter is requested.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
None.
