poISubcase GetDerivedFunction
Returns the function type of an envelope derived subcase.
subcase_handle GetDerivedFunction
HyperView Tcl Query
This command returns the function type of the envelope subcase. The return value will be one of: min, max, extreme, or range. This command returns Error if the derived subcase type is not of the type "envelope".
To get the function type of an envelope subcase:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetSubcaseHandle subcase_handle 1
# Get the function type
set func_type [subcase_handle GetDerivedFunction]
hwi CloseStack
None.
