poISubcase GetDerivedSimulationSubcase
Returns the ID of the original subcase which was used to create this particular simulation of the derived subcase.
subcase_handle GetDerivedSimulationSubcase simidx
HyperView Tcl Query
This command returns the ID of the original subcase which was used to create this particular simulation of the derived subcase.
- simidx
- The simulation index within the derived subcase.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
set scid [result_handle AddSubcase];
result_handle GetSubcaseHandle subcase_handle $scid
subcase_handle SetDerivedType “superposition”
subcase_handle AppendSimulation 3 0;
subcase_handle AppendSimulation 4 1;
set a1 [subcase_handle GetDerivedSimulationSubcase 0];
set a2 [subcase_handle GetDerivedSimulationSubcase 1];
# The variable a1 will have a value of 3 and the variable a2 will have a value of 4
hwi CloseStack
Returns "0" if an invalid simulation index is passed.
