poISubcase GetSyncValue
Returns the simulation sync value corresponding to the passed index.
subcase_handle GetSyncValue index
HyperView Tcl Query
This command returns the sync value for the index specified. The sync value that is returned is usually the time step, or frequency value, at which the results are computed.
index
The simulation index.
To get the simulation sync value:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetSubcaseHandle subcase_handle 1
# Get the sync value for index 2
set sync_val [subcase_handle GetSyncValue 2]
hwi CloseStack
Returns 0 if an invalid index is specified.
