poISweepCtrl SetEnableState
Enables/disables the state of the axisymmetry controller.
poISweepCtrl_handle SetEnableState state
HyperView Tcl Modify
This command sets the state of the axisymmetry controller.
state
The boolean value which controls if axisymmetry will be enabled.
To set the enable state of the axisymmetry controller:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSweepCtrlHandle sweep_handle
sweep_handle SetEnableState true
hwi CloseStack
Returns a non-zero value if an error occurs.
