poISymmetry GetCirPattern
Gets the parameters which were used for a circular copy.
sym_handle GetCirPattern
HyperView Tcl Query
This command returns the parameters which was used for a circular copy.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSymmetryCtrlHandle sym_handle
set params [sym_handle GetCirPattern]
hwi CloseStack
Returns an empty string if an error occurs.
