poISymmetry GetMirrorSystem
Gets the coordinate system which was used for the reflect operation.
sym_handle GetMirrorSystem
HyperView Tcl Query
This command returns the system which was used for the mirror operation.
To get the system which was used for a mirror operation:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSymmetryCtrlHandle sym_handle
set sys_id [sym_handle GetMirrorSystem]
hwi CloseStack
Returns an empty string if an error occurs.
