poISymmetry GetOrder
Gets the order of symmetry operations.
sym_handle GetOrder
HyperView Tcl Query
This command returns the order of symmetry operations. See the list below for the meaning of each return code:
0
mirror, rect pattern, circ pattern
1
mirror, circ pattern, rect pattern
2
rect pattern, mirror, circ pattern
3
rect pattern, circ pattern, mirror
4
circ pattern, rect pattern, mirror
5
circ pattern, mirror, rect pattern
To get the sequence of symmetry operations from the symmetry control:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSymmetryCtrlHandle sym_handle
set num [sym_handle GetOrder]
hwi CloseStack
Returns an empty string if an error occurs.
