poISystem SetOrigin
Sets the origin for the coordinate system.
system_handle SetOrigin origin_str
HyperView Tcl Modify
This command sets the origin of the coordinate system. The origin can be set for user-defined systems only!
- origin_str
- The X, Y, and Z coordinates of the system origin.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetUserDefinedSystemHandle sys1 “UserSystem 2”
sys1 SetOrigin “5.0 2.0 3.0”
hwi CloseStack
Returns a non-zero value if there is an error.
