poISystemCtrl GetEntitySystemType
Gets the current entity system type for the system review control.
sysctrl_handle GetEntitySystemType
HyperView Tcl Query
This command retrieves the current entity system type in a system review plot (for example - ply, system, etc.).
To get the current entity system type in a contour plot:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetSystemCtrlHandle sysctrl_handle
set sys_type [sysctrl_handle GetEntitySystemType]
hwi CloseStack
Always returns a valid entity system type (as long as a valid result file has been attached to the model). If no results were attached, the system control handle is not retrievable, thus this command cannot be called.
