poITensorCtrl SetDimensionEnabled
Sets the dimension state: enabled or disabled.
poITensorCtrl_handle SetDimensionEnabled dim_label state
HyperView Tcl Modify
This command sets the dimension state: enabled or disabled.
dim_label
The dimension label: line, shell, or solid.
state
True if enabled, or false if disabled.
Returns 0 if successful, otherwise an error code.
