poITensorCtrl SetEnabled
Sets the dimension state, either enabled or disabled.
poITensorCtrl_handle SetEnabled pool state
HyperView Tcl Modify
This command sets the dimension state, either enabled or disabled.
pool
The pool from which to set the enable state.
state
True if enabled, otherwise false.
Returns 0 if successful, otherwise an error code.
