poITextAttribute SetVerticalAlignment
Sets the font vertical alignment.
poITextAttribute_handle SetVerticalAlignment align
HyperView Tcl Modify
This command sets the font vertical alignment.
align
The vertical alignment for the text. Options include: "top", "center", and "bottom".
To center the text horizontally:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetLegendHandle myLegendName 1
myLegendName GetHeaderAttributeHandle myAttrName
myAttrName SetVerticalAlignment center
Returns 0 if successful, otherwise an error code.
