poITextAttribute SetVisibility
Enables/disables the text display.
poITextAttribute_handle SetVisibility enable
HyperView Tcl Modify
This command enables/disables the text display.
enable
True
The text is displayed.
False
The text is not displayed.
To turn the text off:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetLegendHandle myLegendName 1
myLegendName GetHeaderAttributeHandle myAttrName
myAttrName SetVisibility false
Returns 0 if successful, otherwise an error code.
