poITracingCtrl RemoveSimStepFromList
Removes a simulation step index from the list of simulation steps that are traced.
poITracingCtrl_handle RemoveSimStepFromList stepIndex
HyperWorks Tcl Modify
When the tracing mode is LIST, this command will remove the index of a simulation step from the list of simulation steps that are traced. The index must be valid for the current load case.
- stepIndex
- A valid simulation step index.
hwi OpenStack
if {[catch {
hwi GetActiveClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetTracingCtrlHandle tc_handle
tc_handle AddEntity node "Node 251"
tc_handle AddEntity node "Node 197"
tc_handle SetEntityColor node "Node 197" "255 0 0";
tc_handle SetMode list;
tc_handle SetSimSteps "0 1 2 3 4 5 6";
tc_handle RemoveSimStepFromList 6;
set mode [tc_handle GetMode];
set sList [tc_handle GetSimStepList];
set traceColor [tc_handle GetEntityColor node "Node 251"];
set traceColor2 [tc_handle GetEntityColor node "Node 197"];
} result]} {
global errorInfo;
puts stderr $result;
puts "[session_handle GetError]";
puts stderr "*** Tcl TRACE ***";
puts stderr $errorInfo;
} else {
puts "********";
puts "Mode = $mode";
puts "Steps = $sList";
puts "********";
puts "No errors.";
puts "Warnings: ";
puts " [session_handle GetError]";
hwi CloseStac
Console Output:
Mode = list
Steps = 0 1 2 3 4 5
No errors.
Warnings:
Returns HW_InvalidHandle if the tracing control handle is invalid.
