poIVectorCtrl GetThresholdMax
Gets the maximum threshold.
poIVectorCtrl_handle GetThresholdMax
HyperView Tcl Query
This command retrieves the maximum threshold.
None.
View new features for HyperWorks Desktop 2020.1.
Gets the color for a given vector component.
Gets the color mode for vectors.
Gets the current plot style.
Gets the current data component label.
Gets the current vector data type label.
Gets the vector control display mode.
Gets a list of vector control display modes.
Gets the pool state, either enabled or disabled.
Gets an auto load/unload vector data state.
Gets the font name being used to draw the vector plot text in the graphics area.
Gets a handle to the poITextAttribute interface for the vector plot text.
Gets the current layer label.
Gets the legend control object for vector control.
Gets the multiplier for vector results.
Gets a list of all the vector plot styles stored in the vector controller.
Gets the result system ID.
Gets the scale value used to display vectors.
Gets the scale mode used to display vectors.
Gets the size of the selection set.
Gets the vector plot text color.
Gets the enable/disable state of the maximum threshold.
Gets the minimum threshold.
Gets the enable/disable state of the minimum threshold.
When nodal results are in use, multiple results may exist for nodes along part boundaries. In these cases, the returned list will contain the first nodal value encountered, while the nodal values for the other parts will be omitted.
Removes a plot style with the specified name.
Renames an existing/old plot style with a new name.
Resets the vector controller settings with a memorized plot style.
Sets the component color.
Sets the color mode for vectors.
Sets the current plot style.
Sets the data component for a given component label.
Sets the data type for the vector control.
Sets the vector control display mode.
Sets the dimension state, either enabled or disabled.
Sets the auto load/unload vector data state.
Sets the font by name.
Sets the current shell layer.
Sets the multiplier for the vector results.
Sets the result system ID.
Sets the scale value used to display vectors.
Sets the scale mode used to display vectors.
Sets the selected entities to be used by the vector control.
Sets the current layer.
Sets the vector plot text color.
Sets the maximum threshold.
Sets the enable/disable state of the maximum threshold.
Sets the minimum threshold.
Sets the enable/disable state of the minimum threshold.
ON THIS PAGE
HyperView Tcl Query
None.
ON THIS PAGE
