poIVectorCtrl SetEnableState
Sets the auto load/unload vector data state.
poIVectorCtrl_handle SetEnableState state
HyperView Tcl Modify
This command sets the auto load/unload vector data state.
Note: Setting the enable state to false causes the currently loaded data to be unloaded.
state
True if the vector data can be loaded, otherwise false.
Returns 0 if successful, otherwise an error code.
