tblITableEditor GetColumnIndex
Returns the index of a column.
tblITableEditor_handle GetColumnIndex columnname
HyperWorks Tcl Query
Returns the index of a column for a given column name.
columnname
Index of the column.
Get the column index (50) from the column name (AX) and save it in a variable:
set t [hw::GetT]
set activetableHandle [hwi GetActiveClientHandle ch$t]
set indexColumnAX [$activetableHandle GetColumnIndex AX]
