tblIRule GetValue
Returns the reference value used to compare with the actual value in the cell to determine if the cell passes the rule.
tblIRule_handle GetValue
HyperWorks Tcl Query
This command retrieves the reference value used to compare with the actual value in the cell to determine if the cell passes the rule. Returns the reference value or an empty string.
set t [hw::GetT]
set activetableHandle [hwi GetActiveClientHandle ch$t]
set ruleid [ch$t AddRule]
set ruleHandle [$activetableHandle GetRuleHandle rh$ruleid $ruleid]
$ruleHandle SetCellList "A1 A2 B1 B2"
$ruleHandle SetBackgroundColor 3
$ruleHandle SetTextColor 0
$ruleHandle SetValue 10
puts "Rule Id: $ruleid will use [$ruleHandle GetValue] as the reference value."
$ruleHandle SetOperator ">"
$ruleHandle ReleaseHandle
None.
