vidIVideo DrawMeasure
Draws the measuring line.
vidIVideo_handle DrawMeasure
HyperWorks Tcl Modify
This command draws the measure line that is used for measuring within the video.
Note: You must use SetMeasurePoint1 and SetMeasurePoint2 before drawing the line.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle Video;
Video SetMeasurePoint1 400 68;
Video SetMeasurePoint2 600 68;
Video DrawMeasure;
Keywords
  • HyperWorks
  • Tcl
  • Video
  • Create
  • Modify
