vidIVideo GetTolerance
Determines the tolerance.
vidIVideo_handle GetTolerance tolerance
HyperWorks Tcl Query
This command finds the tolerance. Tolerance is the allotted difference in timing between two videos. If the timing between two videos is greater than the tolerance, the second video (or third, fourth, and so on) will not play the frame(s) corresponding with that specific time.
Note: For this function to work, at least two videos must be on the page. This command returns the tolerance.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle Video;
Video GetTolerance;
Success (the tolerance) or an error message is returned.
Keywords
  • HyperWorks
  • Tcl
  • Video
  • Query
