vidIVideo SetStretch
Sets whether the video is stretched.
vidIVideo_handle SetStretch on
HyperWorks Tcl Modify
This command sets whether the video is stretched within the window.
on
A true or false value. If you want the video stretched, input true. If you do not want the video stretched, input false.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle Video;
Video SetStretch true;
Keywords
  • HyperWorks
  • Tcl
  • Video
  • Modify
