vidIViewControl ZoomIn
Zooms into the video.
hwIViewControl_handle ZoomIn
HyperWorks Tcl Modify
This command zooms into the video, but keeps the space that the video takes up the same. However, this cuts off part of the clip’s area due to it being larger than the original video space.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetViewControlHandle vc;
vc ZoomIn
Returns success (0) or an error code.
Keywords
  • HyperWorks
  • Tcl
  • Video
  • Modify
