Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Imprint Surfaces
Use the Imprint tool to imprint points, nodes, lines, or surface onto target surfaces, thus creating new fixed points or edges.
Combine, Subtract, Intersect, Detach Solids
Use the Boolean tool to combine solids, subtract one solid from another, detach solids, and find the intersection out of the solids.
Find and Fill Cavities
Use the Plug tool to find and fill cavities. The Plug tool can also be used to remove protrusions, holes, and complex features.
CAD Update
In this section you will learn about updating CAD metadata and parameters.
