Quickly find and open the tools, panels, and browsers that are available from the ribbons or from the Utility
Browser, as well as create entities and solver cards.
Several tools require you to define a plane or a vector direction to perform a certain function, such as dragging
geometry along a vector, spinning it about an axis, or splitting it with a plane. Using the Vector tool, both planes and vectors can be defined as needed.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Define Orientation
Several tools require you to define a plane or a vector direction to perform a certain function, such as dragging geometry along a vector, spinning it about an axis, or splitting it with a plane. Using the Vector tool, both planes and vectors can be defined as needed.
