Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
A mass element rests on a node and is used to represent mass. Mass elements are element config 1 and are displayed
as a dot with the letter M written at the centroid of the element.
A gap element is an element created in a space between two nodes, or between a node and an element, of a model where
contact may occur. Use a gap element when you want to impose a nonlinear constraint on a model; this constraint will
limit the amount of movement possible during analysis.
Many of the methods to check and edit mesh are based around determining mesh quality, but others check for mesh penetration,
detect holes, and locate edges or features.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Create and Edit Mass Elements
A mass element rests on a node and is used to represent mass. Mass elements are element config 1 and are displayed as a dot with the letter M written at the centroid of the element.
Create and Edit Springs
A spring element is an element created in a space between two nodes of a model where a spring connection is desired.
Create and Edit Gaps
A gap element is an element created in a space between two nodes, or between a node and an element, of a model where contact may occur. Use a gap element when you want to impose a nonlinear constraint on a model; this constraint will limit the amount of movement possible during analysis.
Create Spotwelds
Use the Spotweld Tool to create 1D elements to connect different parts.
