Convert model files from one solver format to another.
Note: Depending on the solver conversion, certain options, such as defining a source
template, a destination template, or a configuration file, may not be
present.
Load your model in HyperWorks.
From the menu bar, go to and select a solver format.
A conversion browser opens.
Tip: Click
next to a
solver format to change solver profiles.
In the Source template field, select the appropriate template for your source
solver.
In the Destination template field, select the appropriate template for your
destination solver.
The Configuration File field is automatically populated. The default
file,
ConfigurationFile.txt, provides a valid mapping
scheme for the conversion.
Individual entities are listed in the browser, and
color coded green, orange or red to highlight to which extent the card is
converted to the targeted solver.
Define a Log file location.
Click Conversion Options to view more options.
Review entities.
Click Convert.
A dialog opens, informing you of the status of the conversion. After the
conversion, the user profile is automatically updated to the selected solver's
format. Click Close to close the status
window.
